Enables spanning tree commands. Use these commands to configure the errdisable, multiple spanning tree and portfast settings.
spanning-tree errdisable recovery [cause bpduguard|interval <10-1000000>]
spanning-tree | Configures spanning-tree related parameters |
errdisable | Disables or shuts down ports where traffic is looping, or ports with traffic in one direction |
recovery | Enables the timeout mechanism for a port to be recovered. This option is disabled by default. |
cause bpduguard | Specifies the reason for errdisable
interval <10-1000000> | Specifies the interval after which a port is enabled
spanning-tree mst [<0-15> priority <0-61440>|cisco-interoperability [enable|disable]|enable|forward-time <4-30>|hello-time <1-10>|instance <1-15>| max-age <6-40>|max-hops <7-127>|region <LINE>|revision <0-255>]
mst | Configures Multiple Spanning Tree (MST) commands The MSTP provides an extension to STP to optimize the usefulness of VLANs. MSTP allows for a separate spanning tree for each VLAN group, and blocks all but one of the possible alternate paths within each spanning tree topology. |
<0-15> priority <0-61440> | Specifies the number of instances required to configure MST. Select a value from 0 -15.
cisco interoperability [enable|disable] | Enables CISCO interoperability Enables interoperability with CISCO‘s version of MSTP, which is incompatible with standard MSTP. This setting is disabled by default. |
enable | Enables MST protocol |
forward-time <4-30> | Specifies the forwarding delay time in seconds
hello-time <1-10> | Specifies the hello BDPU interval in seconds
instance <1-15> | Defines the instance ID to which the VLAN is associated
max-age <6-40> | Defines the maximum time to listen for the root bridge
max-hops <7-127> | Defines the maximum hops when BPDU is valid
region <LINE> | Specifies the MST region
revision <0-255> | Sets the MST bridge revision number. This enables the retrieval of configuration information.
spanning-tree portfast [bpdufilter|bpduguard] default
portfast [bpdufilter| bpduguard] default | Enables PortFast on a bridge
If a bridge does not hear BPDUs from the root bridge within the specified interval, assume the network has changed and recomputed the spanning-tree topology.
Generally, spanning tree configuration settings in the config mode define the configuration for bridge and bridge instances.
MSTP is based on instances. An instance is a group of VLANs with a common spanning tree. A single VLAN cannot be associated with multiple instances.
Wireless Controllers or service platforms with the same instance, VLAN mapping, revision number and region names define a unique region. Wireless Controllers or service platforms in the same region exchange BPDUs with instance record information within.
nx9500-6C8809(config-profile-TestNX5500)#spanning-tree errdisable recovery cause bpduguard nx9500-6C8809(config-profile-TestNX5500)#spanning-tree mst 2 priority 4096 nx9500-6C8809(config-profile-TestNX5500)#show context profile nx5500 TestNX5500 mint link ip 1.2.3.4 mint level 1 area-id 88 bridge vlan 1 bridging-mode isolated-tunnel ip igmp snooping ip igmp snooping querier radius nas-identifier test radius nas-port-id 1 neighbor-info-interval 6 neighbor-inactivity-timeout 500 spanning-tree mst 2 priority 4096 spanning-tree errdisable recovery cause bpduguard autoinstall configuration --More-- nx9500-6C8809(config-profile-TestNX5500)#
no | Disables or reverts settings to their default |
